Ken's bar worked out quite well this fall. For anyone considering this purchase, you won't go wrong.
Dyno Dom’s Sikeston Dragway Track elevation 315’ 30.01 station pressure -437 DA 53.3 degrees 24.5% 1.250 3.694 5.790 117.29 1.356 (with the back tires. Tripped with the front tires ~1.246 based on past data and based on the pickup in 330’) 3.678 5.777 117.29 1.252 3.690 5.782 117.32 Picture from Tulsa Raceway Park ![]()
'67 Camaro 1.25 5.77 @ 118 Last edited by 40Coupe; 11-13-2014 at 09:35 PM. |
Liked 201 Times in 52 Posts
Garret,what happened to the stock hood? I think that hot rod would hook in a car wash
![]() Kevin |
Thanks. I still have it, I just got tired of running the car without an air cleaner. The suspension is working really well now.
'67 Camaro 1.25 5.77 @ 118 |
Where are the "wasted motion" naysayers anyway? Probably not many hanging out here at CR! Funny thing is, if I showed all the videos minus the timeslips many would choose the lowest wheelie as the quickest run. In fact, the quickest of that bunch of runs was the highest wheelie where the car pulled the tires past the 60 foot. Just listen to how happy the engine was on the 5.77
Liked 10,918 Times in 2,256 Posts
Are they faster than the two wheel set up?
#6 | |
Liked 662 Times in 187 Posts
I ended up buying my dads gold 67 and I'm setting it back up for A/S !! Good job on your car!
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
I can't answer that. This is the only bar I've run and it's works great. You can set it up nice and high so it's really only back there as a safety item. When the car comes up you can feel it going into the normal wheelie then once it starts getting to the peak it just stops climbing. The car also seems to go straight.
The best peace of mind and damage control item I've purchased since I started racing! No more smashed headers, etc. should I miss the shock tune up.
#8 | |
Man I miss KCIR and the good old F body shootout days. Those were some fun times! I can still remember you standing the gold 67 on the bumper with the 350 4-speed combo running mid 10's. That thing left like a beast!
Yeh fun times for sure ,I'm hoping it leaves as nice with the 396 in it
