Liked 22 Times in 22 Posts
James, you make some very good points. I'm not denying what you say is true. That being said, the reason I was going with true clutch assisted is because of all the fans of drag racing that I have talked to about this, is the one thing they miss the most other then dry hops, are the guys having to clutch and shift. They say clutchless cars and autos are boring. Just trying to make it more of a drivers race. And one more thing I'm interested to know, and and not being smart, I truly want to know. Why do so many SS and Comp guys have 6 or 7 different $4,000 dollar clutch setups if they are all good? I'm saying you take that part of the equation out. I've tried virtually every single disc, clutch assisted setups they made, and never found much over .03 in all of them. That can't be said for the other setups. Found more in the fly wheel wt. then different clutch models.
don,t have one |
Liked 1,436 Times in 299 Posts
I think the clutch assisted is fine, but even those transmissions won't look a lot different to the average fan. No one will be clutching them. They will cost less than the average clutch less though.
As far as clutches go, we have never purchased one new. We just have them rebuilt to our specs. Some guys have a lot of them for the same reason they have 3 engines at 40k each, because they can. There is et in the hot dog clutches if you are willing to test and you are willing to treat the clutch as a wearable item. You need to slip it to be fast. That means they will wear out. Because they will wear out, you better have two so you aren't down too long when it needs service. Usually guys that like the heavy stuff only do because they dead hook it. They last forever, but they won't be as fast. Get a small light clutch and work it over! Some of the very small stuff out there has a small tuning window. One screw up in the bell housing or the burnout box and you are pulling it out. Ask the auto guys that are fast how many convertire they test and how many transmissions they have. When we raced autos we were on our backs smelling transmission fluid all of the time! The automatic guys have been babied long enough when they have to race stick guys. In a true clutch less environment they might have a case for a few lbs, but not when they race against clutch assisted transmissions. Not a bad idea, the spec class, but I do agree, you need something that will give racers confidence that the class will be around awhile. The coyote class deal would be cool if chevy and mopar stepped up also. None of this is easy to get started, or to police when it does get started. if you drummed up some support from the big three, it might hang in there awhile
James Schaechter 3163 STK Last edited by james schaechter; 11-16-2014 at 04:44 PM. |
Thank you James. A truly unbiased intelligent post.
don,t have one |
