Old 11-16-2014, 07:49 AM   #31
SSDiv6
Default Re: Is this mod allowed ??????
Take a look at this link for a fuel cell installation on a Fox body.
http://www.fast351.com/cartech/fuelcellbox/
Old 11-16-2014, 12:26 PM   #32
Tony Goodman
Liked 18 Times in 4 Posts
Questions should be directed to your division tech director. If it's a gray area get the answer in writing and throw it in your glove box.
Tony Goodman is offline   Reply With Quote
Old 11-16-2014, 08:55 PM   #33
Rory McNeil
But is that Mustang a Stocker? I`d be suprised if NHRA would be OK with somebody cutting out most of the OE trunk floor, and fabricating a panel.
NHRA 6390 STK
M/S 85 Mustang
Old 11-16-2014, 09:12 PM   #34
Rory, I almost think you could slip that by ,with the same gauge metal.
Seems like a bunch of work to gain what? ..A usable trunk?
I always thought high and back (and simple) ..is best.
Old 11-16-2014, 09:23 PM   #35
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
That was a street driven car with a large capacity tank. He was having problems with fuel delivery when tank level was low.
Rich Taylor
I/SA - 321
Old 11-16-2014, 10:22 PM   #36
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Where the tank is mounted and if the pump is above the tank sump can cause cavitation issues with a good pump. If the pump has to draw fuel up, it can boil the fuel (cavitate). Like Mark pointed out the tank being high and to the back is the way to go. How you fabricate the firewall makes a difference, and can look like it was factory installed.
Sean
Sean Marconette
84 Mustang
5060 SS/N
