Liked 427 Times in 97 Posts
Contact The "Lil" "Drummer Boy"
![]() Jerry forgot more about Camaro's than most know! http://z28camaro.com/wp/contact-info |
Liked 56 Times in 31 Posts
I did this with a Z28, which I had 10 years ago.
All I needed was a Standard Steering box, of which I had a couple on the shelf and a Quick Ratio Pitman Arm, which I found on E-Bay. Check out this page, http://www.camaros.org/suspen.shtml#steer Hope this helps.
Thomas NHRA 1959 D/SA |
Liked 46 Times in 29 Posts
I have an additional question on the answer.
Do you need to find a correct corresponding idler arm to match the new pitman arm to keep center link level and centered? Chris |
#4 | |
It depends on what is in the car now. If you are only changing from power to manual steering and are not changing from quick ratio to standard or vice versa, you do not need to change the idler arm. That is why using the correct pitman arm is important.
Liked 880 Times in 311 Posts
I had a 69 Z that I did the change on. I pulled everything from a 1967 6 cyl Camaro. I took from spindle to spindle. The drag link was smaller diameter and the complete assy weighed less. I would think twice about the quick steering on a drag car. I always use the slower steering rack & pinions in cars I build. Think about it: Quicker steering might cause a driver to over correct during a problem run. I've see more crashes where drivers over correct than crashes where they don't correct enough. Just my .02 for free!
Adger Smith (Former SS) Last edited by Adger Smith; 11-23-2014 at 09:43 AM. Reason: sp |
Thanks, guys. I emailed with Jerry as suggested. That, along with what I read here, says get the manual box and the pitman arm....if anyone else has anything to add please feel free to add! Thanks again, Jeff
Also, how much weight difference between the power and manual setups?
