Old 11-22-2014, 02:22 PM   #31
Liked 1,880 Times in 422 Posts
Default Re: How many 9 second 396/375 alum head A/S A/SA
Originally Posted by Cdncarnut View Post
This is where things get a bit confusing for a newbie like me.
So, the NHRA allows someone to run an engine combination which was not available for that model year, yet I cannot run a cowl induction hood for the 350/255 combo because the engine option was cancelled before the cowl hood was released?
After checking the classification guide, I noticed that aluminum heads are also legal for the '69 iron block 427, even though that was never offered from the factory.
See my post above.
The GMPP 401 aluminum head is listed as an NHRA accepted replacement part for the early cast iron big block Chevy closed chamber rectangle port head. There is a HP penalty for using the aluminum replacement head. For example, we used them on a 69 Camaro 427/425, and that raised the HP rating from 425 to 435, so we had to add 80 pounds when running them in A/SA.
There are certain parts allowed by NHRA as replacements for old castings that are both difficult to find, and expensive to buy. In the case of cylinder heads, a HP penalty is applied, it usually starts at 10HP.
In the case of the 401 head, it is not allowing a different engine combination, it is allowing the 401 head to be used as a replacement for the OE head, with a HP penalty applied.
The same applies to some heads for other makes. An aluminum replacement head is allowed for certain combinations, and it carries a HP penalty.
Old 11-22-2014, 02:34 PM   #32
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
Thank you for the clarification.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
Old 11-22-2014, 03:32 PM   #33
Liked 10,822 Times in 2,250 Posts
Ken you have a very good car, but a 70 Nova should be 402/ 395 iron, or 402/ 405 aluminum.
Old 11-22-2014, 05:12 PM   #34
Ken Keir
Liked 18 Times in 8 Posts
Hi Larry, You are correct. I have both combinations
Ken Keir
Ken Keir is offline   Reply With Quote
Old 11-22-2014, 06:23 PM   #35
FINESPLINE
FINESPLINE's Avatar
Ken Keir
And that car looks great doing it---- with either combination !
FINESPLINE is offline   Reply With Quote
Old 11-22-2014, 07:50 PM   #36
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
Definatley some very fast 396's out there!!
I think A/S will be cool this year too!
Hopefully with the new cars in there own classes it should bring back some old school cars. .
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 11-23-2014, 12:17 AM   #37
billy leber
Liked 10 Times in 1 Post
I went 9.95 in Dan Fletchers car with that combo in the semis in Pomona a few years ago. Unfortunately it was heads up and Jimmy DeFrank went 9.74. It was a 375 h.p. rating at the time but I'm sure Jimmy can still go 9's .
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC
billy leber is offline   Reply With Quote
Old 11-23-2014, 09:39 AM   #38
I think Jimmy, Joe, and Lance can all go 9's in B/SA.
Old 11-24-2014, 07:51 PM   #39
Doug McCue
Liked 13 Times in 2 Posts
well if the cars are built with NHRA specs, I would be surprised any of them could
Doug McCue is offline   Reply With Quote
Old 11-24-2014, 09:16 PM   #40
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
You do realize these cars go through an NHRA teardown and I can assure you Jimmy D's is to NHRA spec from that perspective.
TP
Pedigo Perf is offline   Reply With Quote
