Old 11-25-2014, 06:34 PM   #1
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: 2015 AA/S and AA/SA Could Be Very Exciting
Yes I knew it was cc but I thought maybe it would be changed for the new year.
Old 11-27-2014, 10:19 PM   #2
Mike Keener
Liked 24 Times in 13 Posts
I find this an absolute mistake! I can't believe anyone could possibly think that a traditional stocker could ever qualify at Indy running off a 10.60 index at 7.5 pounds per factored HP!. This must be changed so we need anyone who cares about running this class to write the committee for an adjustment.asap. If enough racers follow through- perhaps it can be corrected before Indy next year.
IMHO the correct index for this class should be in the 10.75 to10.80 range keeping it in line with A/S.
MK
Mike Keener
A/S B/S
C/SM
Mike Keener is offline   Reply With Quote
Old 11-27-2014, 11:30 PM   #3
Dave Ficacci
Dave Ficacci's Avatar
Liked 98 Times in 23 Posts
Mike,
Happy to hear you are bringing back the old iron. 2015 should be fun again in AA and A like it used to be.
In my opinion the index is just fine where it is and has been for the last 7 years. The 10.60 index allows you to run your car all out for a majority of the season and not worry about HP which is the main reason the class was created with this index in the first place.
If you don't think you can qualify in AA at Indy, you have the option to run A. If you built an AA only car, it is what it is.
There have been plenty of cars running in A capable of qualifying in AA (CC) in years past. To name a one, Ken Keirs Nova has been on what appear to be 9.8x runs in the heat of the day during class eliminations in A. Tuned up in the morning sessions Ken would have no problem getting in the field in AA. I'm sure if David Barton wanted the Coronet to qualify in AA he could as well.
Its funny you mention the "tanks" running in A. Weight was another reason why AA was created several years ago. Many drivers of these "tanks" got into NHRAs ear about how unsafe these car are becoming carrying so much weight and parts breakage was also an issue. Well look back till about 2008/09 when all these "tanks" put the weight back in to run A to avoid the new cars and have been in A ever since...I guess it wasn't about weight and safety after all. In my opinion are too many personal agendas out there and this thread is another example.
To comment on your stick/auto comparison in Top Stock, I don't believe you had two equally built cars with the same combo, one auto, one stick competing in Top Stock did you? I lost interested when crate motors were allowed so maybe you did. Point being you need to look no further than SS/AH in the last 5 years to know the stick is faster. There is a reason everyone switched to a manual, and you know its not because its easier.
Dave Ficacci
1013 STK
1170 SS
Dave Ficacci is offline   Reply With Quote
Old 11-28-2014, 02:04 AM   #4
Mike Keener
Hey Dave,
Good to hear from you. And yes it will be great to race the old iron again.
The majority of the AA cars are removing somewhere between 200 to 225 pounds from their A weight so how much quicker do you think a AA car is over an A car in your opinion?
Also comparison of a stick vs auto is not the same when using the AH cars as an example because they are clutchless transmissions which is a completely different issue. Comparing a clutch assisted stick to an auto is what I was referring to.
Hope to see you some next season!
MK
Mike Keener
A/S B/S
C/SM
Old 11-28-2014, 02:25 AM   #5
Paul Precht
Only a small percentage of the traditional A/SA cars in the country can run a second under in the best of air, they don't need the 10.60 index in AA to give them room. For many, AA will allow them to run quicker with less strain on the drive train, 10.80 would be the best index IMO.
Old 11-29-2014, 04:18 PM   #6
Chuck Norton
Liked 89 Times in 19 Posts
Mike,
Certainly, both of us recall the marathon late-night coffee shop sessions during which the original rules for Top Stock were debated and re-hashed. I recall questioning your position that stick and automatic cars in the upper classes were essentially oblivious to the choice of transmissions and then, months later, watching your position be validated once all the cars were on the same track.
In the end, Top Stock, during the initial event or two that it was contested, before the crate motors were accepted, has remained one of the most striking examples of Stock Eliminator drag racing parity that has been achieved thus far and it was done with paper and pencil, using the framework of existing NHRA horsepower ratings across a variety of platforms and a cross section of cars and drivers, and with every car laying down the absolutely best numbers that it could muster on every pass. You will recall that the top two qualifiers were a stick and an automatic. The top ten qualifiers included six stick cars and four automatics. The final round featured a stick and an automatic, the #4 and #5 qualifiers.
Among the lessons learned at Norwalk in 2000 that directly apply to AA/S and AA/SA:
1. Sticks and automatics CAN run together in the higher HP classes without putting either at a debilitating disadvantage and if the indexes are the same, why have two classes? In the end, track prep and maintenance are the deciding factors. In the case of Top Stock, when the track was good, the stick cars ruled. When the bite went away, automatic cars prevailed. Nothing will be any different in 2015. So, take your pick.
2. In the case of AA/S and AA/SA, with the new cars removed from the equation, leaving the original combinations that are well-known entities, there is no particular performance advantage to the choice of either transmission. Why not give the fans something to get excited about? How could anyone not enjoy seeing pairings such as Hemis versus Thunderbolts, heads-up, flat-out.
3. Indexes mean everything when it comes to qualifying and next to nothing when it comes to racing. The AA class is no different than any other class in Stock Eliminator in this regard. If you plan to run Indy in a AA class with the index at 10.60 you will be at a huge disadvantage against any other class index in the field. And, if you can’t qualify, you don’t race.
With regard to the AA entries, if the committee doesn’t elect to merge the transmissions into a single class, let’s hope that they get it right by assigning fair indexes to them so that they may enjoy the same opportunity to qualify at Indy as any other class. Everyone has a vested interest in parity and a level playing field.
Merry Christmas and a Happy New Year, Mike!
Chuck Norton
Chuck Norton is offline   Reply With Quote
Old 11-30-2014, 12:33 PM   #7
Dave Casey
Liked 797 Times in 165 Posts
Chuck,
Your post reminds me how we miss your contribution to forums like this, not because I share your point of view here, but because you have a way with words.
It sure was a fun deal at the first go around in 2000, I did not have my A car then, I was racing my G/S car and I traveled with John Shaul and enjoyed the whole deal. There certainly was some beer drank and stories told down in that grassy corner in Norwalk.
My car won't run AA, it is a natural B car, that being said, times have changed and I believe the 10.60 index should be raised to 10.75 or 10.80 for both trans.. Speaking of trans, I think there are no advantages stick to auto in the AA,A,B classes. The Hemi cars Dave mentioned are still extremely close, and they have much better trans than stock in the stick cars
Dave Casey 1330 STK
