Old 12-02-2014, 02:38 PM   #1
treessavoy
Liked 4 Times in 4 Posts
Default Re: Max Wedge
Originally Posted by Darcy Clarke View Post
Hi Jim
I had asked NHRA the same thing for my current SS project and I was told that the carbs can have the primary bores inline.
Darcy Clarke
6254
A/SA SS/JA
Thanks Darcy,
Are you building a Hi or Low comp. motor?
Jim Rountree
Old 12-02-2014, 03:41 PM   #2
Darcy Clarke
Liked 528 Times in 36 Posts
Hi Jim
I built the high compression, it's been a real challenge. Which version are you building?
Darcy Clarke
6254
A/SA SS/JA
Darcy Clarke is offline   Reply With Quote
Old 12-02-2014, 05:22 PM   #3
treessavoy
Hi Jim
Darcy Clarke
6254
A/SA SS/JA
Darcy,
I'm pondering building the low comp. It's a '64 Savoy.
JimR
Jim Rountree
Old 12-02-2014, 10:00 PM   #4
Barnstorm
Barnstorm's Avatar
What class were you thinking?
Old 12-02-2014, 11:26 PM   #5
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Originally Posted by treessavoy View Post
Darcy,
JimR
Jim, the low comp is at 395HP compared to 415 for the high comp. If you run the car in SS/EA that's 160lbs difference.
Old 12-02-2014, 11:52 PM   #6
Darcy Clarke
Hi Paul
The intake is a challenge. Have you built a SuperStock Wedge?
Darcy Clarke
6254
A/SA SS/JA
Old 12-03-2014, 09:12 PM   #7
Paul Precht
Hi Paul
Darcy Clarke
6254
A/SA SS/JA
Hi Darcy I haven't built a SS Max but I've done a lot of flow work with the Max and the standard heads with various mani's, stock, aftermarket, sheet metal etc. I'll send you a PM, not sure if it will help but I'll share what I know, Paul.
Old 12-04-2014, 01:10 AM   #8
treessavoy
Paul,
I've been looking at the Mod Man manifold by Indy, it may take some welding to get the right off set but it will clear the hood, of course, the other option is a hand made manifold by Wilson or some one else. If I remember correctly the stock cross ram runs out of flow around 6000rpm.
JimR
Jim Rountree
Old 12-02-2014, 11:00 PM   #9
Paul Precht
Hi Jim
Darcy Clarke
6254
A/SA SS/JA
Hi Darcy, Just wondering where you had trouble as these are pretty simple motors for the most part, I'm thinking the mani would be the most challenging part as well as hood clearance.
