Yeppers, or rear tires.
Ed Wright 4156 SS/JA |
Liked 165 Times in 51 Posts
What are the wights of the this 3, 9x30 radials?
Hoosier M/T GOOD YEAR
Glen DeMenge 1969 Camaro Stock Eliminator |
Liked 11 Times in 8 Posts
Can't comment on any performance increases, I've always bought the lite stuff. On a new build I'd say pay the extra money and go lite, not sure if I'd purchase "extra" lite components trying to improve performance. In my opinion engine upgrades, convereter, gearing would be a better place to spend that money.
Joe Buchanan SS/BX 3117 |
Glen, I don't use 9" tires. I have no idea.
Liked 333 Times in 180 Posts
MEXJOE---- about 22.7---23 pounds per tire depending on the brand--FED 387
Liked 126 Times in 20 Posts
Use aluminum
Tim Worner SS 1747 |
the use of JUST a steel or aluminum driveshaft alone is not going to give you any significant reduction in ET--- however when used in conjunction with many other "performance/lightweight" parts the overall performance of a particular vehicle should improve. It all depends on the parts selected and the individual vehicle-- some will see improvements while others may maintain the status quo or its even possible that your performance "may" not be as good as before---- it also might just contribute to parts longevity.--there is no firm answer to this question--- in some instances steel is the way to go while in other situations an aluminum driveshaft is the answer--you just have to experiment and observe what a " quick" similar classed vehicle is using and how your performance compares to that one--- FED 387
If nothing else, I think it may soak up some shock to the gears in a Trans brake or stick car.
And a steel spool may be enough more rigid to improve gear set life.
I've won and lost by .003. If you are in this game to win, you do it all. Everything!
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
