#31 |
Liked 21 Times in 3 Posts
For what it's worth.......when I had the crate motor in my car my aluminum radiator filled with water weighed 1.5 lbs. less than my stock 340 radiator filled with water. PLUS.......my stock radiator cooled much better.
#32 |
Liked 33 Times in 16 Posts
Brent - I weighed both radiators today and was surprised...the factory one is 14 pounds and the new one is 11 pounds.
Rich Taylor I/SA - 321 |
#33 |
Liked 780 Times in 194 Posts
And remember that the water will add a lot of weight (1 lb/pint).
#34 |
Great! Im runnin a 4 row right now(brass)...so its pretty dang heavy...and runnin more liquid than i need...
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
#35 |
[QUOTE=HandOverFist;455119]Brent - I weighed both radiators today and was surprised...the factory one is 14 pounds and the new one is 11 pounds.[/QUOTe
Were you running a 3 row? or 4 row? before you changed to alum... Was this the camaro radiator that you weighed?
#36 |
[QUOTE=Travis Miller;455084]According to Bruce Bachelder, it does not have to be an exact replacement. A cross flow can even replace a top tank or it can be the other way around.
This new rule is about NHRA allowing Stock racers to use an aluminum radiator to replace the hard or impossible to find OEM one. It is not about who can push the rule by installing the smallest aluminum radiator that can be found. That would just raise a red flag for us to take a harder look at the entire car.[/QUote I wonder if any bracket fabbing is allowed?
#37 | |
[quote=brent flynn;455134]
![]() Here's one that should bolt right in your car Brent with no mods... http://www.ebay.com/itm/271450398612...%3AMEBIDX%3AIT
Rich Taylor I/SA - 321 Last edited by HandOverFist; 12-13-2014 at 05:07 AM. |
#38 |
Liked 7 Times in 5 Posts
you do know that the hoses are reversed on a Ford , might make it hard to install in the Camaro..
#39 |
Liked 224 Times in 87 Posts
Is there a big price differance between champion and be cool radiators . Never really looked at any of them in the bracket cars when in the lanes , is there a quality issue where .I like the champion small 3/4 core 2 row . For the camaro
#40 |
Here it is in the '90 Mustang...fits fine even with the tweaked radiator support.
