Old 12-15-2014, 11:29 AM   #1
dennis dunlap
Default Re: Olds W-30 Carb
Tony, you are correct '70 442 w-30 manual trans hardtop or convertable 'auto trans is a 7040258 .Dennis, you have a pm thanks
dennis dunlap is offline   Reply With Quote
Old 12-15-2014, 04:00 PM   #2
SSDiv6
Liked 1,604 Times in 583 Posts
It's also worth a lot of $$$$!
Old 12-19-2014, 01:56 PM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
A lot of those carburetors were used on jet pump installations for boats. A company in North Little Rock built the installation packages - engines w/pumps attached - back in the 70s-80s. Jacuzzi is a Little Rock based company. Not sure it was the same number, but they did not have a power piston. I had several once upon a time.
Old 12-19-2014, 09:08 PM   #4
t.tosto
Liked 62 Times in 23 Posts
Thanks to all who responded. I do restorations on GM muscle car Holly and Q-Jets, worked for Olds dealer in the 70's but never experienced this particular set up. Will run carb on test engine after restoration, wonder how the transition from idle to part throttle will be? Tony Tosto #3050 B/S
t.tosto is offline   Reply With Quote
Old 12-20-2014, 01:21 AM   #5
Tony, I suspect that if you have a mild ,short duration camshaft in the test engine ,it won't like it.
The W30 stick cam had a bunch of duration in it. I'm sure that was the reason for doing this.
Still surprised they did that, before HEI's were around to help clean up the mixture.
