looking for either of these 4 bolt main small blocks, 3932386 or 3956618. dated 1969 january thru may.contact rbullard1941@yahoo.com or robert at 910 840 3951
Liked 336 Times in 183 Posts
try racing junk item #969360----no date listed---Comp 387
thanks FED 387
I have 3956618 block 4bolt main with c/27/9 date code if you are still interested call my shop
@ 480-949-8227 thanx! Kenny |
also looking for a set of pink rods????? Z28. they have a 0 stamped on the rod brg cap.
Liked 64 Times in 22 Posts
i have 3 blocks.......1 is "386" cast # with date code of September of '68..........the other is "388" cast # with date code of Feb '69.....3rd is "010" cast # with a mid -to late '69 i think.im trying to go off memory on it,just happen to remember it as i was posting...........if interested let me know..........to any one else looking for "dated blocks" i have several ,mostly s/b but a few b/b,including a '67 427 "351" block & matching alum "392" heads. its 435hp tri-power for '67 vette VIN code JE.......thanks Vic
The engine has the following parts, crankshalf sepecialitys, lighten, nitrated and chromed, eagle rods,edelbrock aluminum heads, comp. cam springs, rollers rockers, solid roller cam, cloyes timing, melling oil pump, deep canton oil pan, edelbrock victor jr. intake, weiand water pump, edelbrock roller fuel pump. 750 fluiddampner .350 cu.in. 4 bolt mains, bored .020 over. dynoed at 504 hp. I have the dyno sheets. $5500. OBO 804-677-3377 or mbullard1@aol.com
. Last edited by milton; 11-03-2007 at 08:57 PM. Reason: new thread |
