Liked 880 Times in 311 Posts
Part # Description
18000 16" Aluminum Degree Wheel 16" Degree wheel is machined from 1/4" Aluminum. Degree marks are machined approximately 1/8" apart so they’re easy to read. Heavy design allows the builder to rotate the engine while “degreeing” the cam. Comes with 7/16", 1/2" and 5/8" bushings. StarMark by BAASEL Laser Tech is our latest addition of services available to all of our customers. The StarMark Diode is a marker beam source with diode pumped YAG (DPY) lasers—particularly suitable for permanent marking of plastics, metals, and high-tech materials. Ideal for integration in production. Mike, YAG is the same kind of Laser they use in some eye surgeries. I guess if it is good enough for your eyes it is good enough for a Degree wheel..LOL! There are wide tolerances with the Silk Screen type others use. You can't keep the silk screen accurate. http://www.pppcenter.com/
Adger Smith (Former SS) |
