Old 12-19-2014, 02:43 AM   #2
rick lester
Liked 4 Times in 1 Post
Default Re: IHRA Stock GT Truck
To run a 1992 S10 in IHRA Stock GT you need a 180 or so hp rated motor if you run the body style as an E.L. and remember you can add weight, ie full fuel cell, weight box. I will say this, adding a rollbar will open your options as far as running a faster class and def. can ask for more money when you sell. 2nd gen is heavier so if you find a good motor you could go with a 95 or 96 body with a higher hp motor and still be in same class.
rick lester is offline   Reply With Quote
