Old 12-24-2014, 05:24 PM   #9
Dick Butler
Liked 32 Times in 19 Posts
Default Re: what size trailer ?
If you use the double side door and al ramps for the golf cart make a pair of stops for the front wheels on the wall to spread the pressure and tie the cart acoss the trailer to keep it as far as possible in the door. I have a metal rear deck/folding seat on the rear of mine and that makes entry hard through the door when the cart is in so be sure all tie down is done first before loading cart. Keep ramps fairly long so cart clears door floor edge. Side mounted winch can pull it in too if needed to control on entry.
I had cabinets in front of trailer but above on side to clear. 28 ft would give space between car and cart if you need to get in to check it or out of rain at track.
My question is impressions of brands Haulmark, etc. I was spoiled with T and E or Goldrush but cutting budget.. Which do people like of lesser expensive brands....
