Liked 160 Times in 51 Posts
Look for features such as individual cylinder tuning/timing good graphing recording/ + ease of active tuning. I have a older commander 950 system and it work's ok, but missing some of these modern system features.
I like where Big stuff uses a floating background that show where you are on your fuel map when you are looking at live data. Can't comment on FAST systems.
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
Liked 27 Times in 6 Posts
In the name of Full Disclosure, I work for FAST so I am biased. I just thought I would let you know about some of our features.
The FAST XFI 2.05 system has internal datalogging with the overlay function mentioned above. This allows you to "see" exactly where you were in any fuel or spark table at a given point in a datalog. This is very helpful in using datalog data to refine your tune. The XFI features dual 25mHZ processors so it can make calculations at a speed of up to 50,000 times per second. That would be 500,000 calculations and fuel / spark decisions per 10 second run. In coil on plug applications, you can use the dwell control feature to dial in the optimum amount of dwell time for your coils to find the best balance between power and coil life. The coil dwell has two tables that will change the dwell with battery voltage, and throttle position. The XFI 2.05 features a 3d table that allows you to perfect your individual cyll corrections over the entire RPM range, not just one correction applied at all RPMs, but dynamic correction that allows you to match the changing airflow characteristics as RPMs change. The XFI 2.05 also features fuel pressure compensation. The need for this comes from the fact that any EFI system uses a constant fuel flow number, you have to tell the ECU what size injector you have and the ECU assumes that that injector flow is constant, but in the real world, injector flow rates vary as the fuel pressure varries causing un-planned corrections needed from the ECU. The XFI monitors fuel pressure and constantly adjusts the reported injector flow rate as fuel pressure changes. The proven true Speed Density strategy that FAST uses is super consistent. I personally tuned three class winners at the US nationals this year using our Load Indexed Speed Density Strategy and it was a breeze because no real adjustments were needed, even using tuneups from other tracks and different atmospheric conditions. It is so consistent because it uses air temperature and air pressure as part of it's base calculations. Once you get a tune dialed in for your combo, there is no need to go in and "Re-Dial it in" when you go to a different track with different altitude, barometer, and temperature. This year at the US Nationals, I had a total of 15 class winners in Super Stock, and 5 class winners in stock. Nick Morris went on to win Super Stock and PB Candies made the fastest SS pass with a 7.859. I had every combo including L98, LT1, LS1, LS2, Modular Ford, Pushrod Ford, Oldsmobile, and Late Model Hemi in our list of class winners. Our tech support team provides on track support at many points meets and Sports National events and I credit our success at Indy to years of helping customers and building relationships. All of the major EFI systems available today will get the job done for you. If anyone tells you their system will make more power than another, run! Do your research, listen to your fellow racers, and make your best decision. Our track record speaks for itself. If you have any questions, I would be glad to answer them and Ill shoot you straight. Also, FAST will offer Training Courses at our headquarters in Memphis. Thanks David Page FAST Last edited by pbp1; 12-27-2014 at 05:56 PM. Reason: Mispelling, Omitted info |
Vote for the Holley Dominator system here.
Very easy to use and the support has been second to none. You can also use the HP system if you don't need as many inputs or outputs. If you start with the HP and need more down the road all harnesses and tunes move right over to the Dominator. The training class was great too.
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
FAST XFI has everything you mentioned there. Great support if you need it, even at the track at major events. I have worked with most systems out there, and personally the new Holley Dominator would be my second choice. FAST for sure is my first choice.
Ed Wright 4156 SS/JA |
Liked 18 Times in 6 Posts
FAST is certainly an consideration also. I didn't find much info at the PRI show so I wasn't really able to lay hands on it. I know Ernie and Dave run FAST and they like the system. I'm not sure what version they have but next time I'm out at their shop I may try to see if I can get the feel of it.
Is the FAST system able to run the Ford Mudular Coil on Plug system? The older modular COP had issues running above 8,250rpm. The new stuff seems to run a little better but some still switch to the LS coils. I've ditched the drive by wire throttle body and the variable cam timing. It will be turning well north of 8,250rpm
2014 Cobra Jet FS/XX #3345 STK/SS Like us on http://www.facebook.com/pages/Daniel...25886327426822 |
If you are talking about Ernie Neal, we upgraded to version 2.05 at Indy. All of our updates are made available at no charge.
The XFI can run a Modular Ford with stock coils, LS coils, or the IGN -1A coils which work very well at high boost levels. As far as an RPM limit, the only thing I am aware of is on the coyote engine, there was an issue with the factory trigger wheel and Ford came out with this "High Rpm" version. |
I hate that we didn't connect at PRI. I would have been glad to go through the software with you.
