Old 01-10-2015, 11:25 AM   #21
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 12 bolt gear set treatment options
Myron.
good idea and sounds reasonable. I can do that because the pinion is already in the housing with an estimated setup shim pack. I was just going down to take the pinion out and box up for shipping so your note came just in time.
Thanks
Larry Woodfin 471W
Old 01-10-2015, 11:27 AM   #22
Dragsinger
Alan,
building a super stocker, any housing is legal
Larry Woodfin 471W
Old 01-10-2015, 12:46 PM   #23
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
We tried everything to get a 5.86 and 6.00 gear to live in our car....350 cu in. 993/997 with 615 estimated and around 510 torque... Mark Williams Caps, LPW Cover, Shockproof Red Line Oil.. ( Still have 5 gallon never opened). Set them up Tight...Loose...Deep...Shallow...Took the housing out and had it completely updated with additional bracing @ PK Racecars....
Never made any difference..@ 25 runs it was making noise...And @ 50 they were gone.You might run them close to a hundred, but you were holding your breath.. I think the weight is very crucial. We were @ 3300. We changed classes and went to a 3000 pound and a 5.57 gear and never had any problems . Can run this set up year after year...Those little pinions don't like weight,
Jeff Niceswanger 3740 SS
Old 01-10-2015, 03:26 PM   #24
Liked 1,911 Times in 428 Posts
So, all these SS cars with 9" rears are illegal? (He isn't building a Stocker.) Boy, I have one of the few legal SS cars around here. LOL
Ed, you didn't read all of that. YOU were talking about a stocker in the post I quoted. I was not talking about Larry's project at all. Our SS/EA 69 Camaro has a Dana 60, I know rear ends from other manufacturers are legal in Super Stock.
Old 01-10-2015, 04:09 PM   #25
Ed Wright
Ed Wright's Avatar
Sorry Alan.
Ed Wright 4156 SS/JA
Old 01-16-2015, 12:42 AM   #26
Dragsinger
I have the 6.0 ratio setup completed and have removed the ring and pinion to be sent for treating. At the suggestion of Myron I shipped the gears here
http://www.procryo.com/index.html
for REM and CRYO processing
Larry Woodfin 471W
Old 01-16-2015, 10:47 PM   #27
Rick Kolber
Liked 32 Times in 13 Posts
I' m planning a 8 3/4 build and was going to cyro and rem the ring and pinion. I know the rem in mirror polishing. Just curious if anyone has gone the anealon treatment (ceramic coating) as apposed to rem finishing? Same for bearings ceramic or anealon coatings. Thanks, Rick
Rick Kolber is offline   Reply With Quote
