#21 |
Liked 99 Times in 60 Posts
Myron.
good idea and sounds reasonable. I can do that because the pinion is already in the housing with an estimated setup shim pack. I was just going down to take the pinion out and box up for shipping so your note came just in time. Thanks
Larry Woodfin 471W |
#22 |
Alan,
building a super stocker, any housing is legal
#23 |
Liked 1,046 Times in 370 Posts
We tried everything to get a 5.86 and 6.00 gear to live in our car....350 cu in. 993/997 with 615 estimated and around 510 torque... Mark Williams Caps, LPW Cover, Shockproof Red Line Oil.. ( Still have 5 gallon never opened). Set them up Tight...Loose...Deep...Shallow...Took the housing out and had it completely updated with additional bracing @ PK Racecars....
Never made any difference..@ 25 runs it was making noise...And @ 50 they were gone.You might run them close to a hundred, but you were holding your breath.. I think the weight is very crucial. We were @ 3300. We changed classes and went to a 3000 pound and a 5.57 gear and never had any problems . Can run this set up year after year...Those little pinions don't like weight,
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 01-10-2015 at 12:54 PM. |
#24 |
Ed, you didn't read all of that. YOU were talking about a stocker in the post I quoted. I was not talking about Larry's project at all. Our SS/EA 69 Camaro has a Dana 60, I know rear ends from other manufacturers are legal in Super Stock.
Alan Roehrich 212A G/S |
#25 |
Sorry Alan.
Ed Wright 4156 SS/JA |
#26 |
I have the 6.0 ratio setup completed and have removed the ring and pinion to be sent for treating. At the suggestion of Myron I shipped the gears here
http://www.procryo.com/index.html for REM and CRYO processing
#27 |
Liked 32 Times in 13 Posts
I' m planning a 8 3/4 build and was going to cyro and rem the ring and pinion. I know the rem in mirror polishing. Just curious if anyone has gone the anealon treatment (ceramic coating) as apposed to rem finishing? Same for bearings ceramic or anealon coatings. Thanks, Rick
