Old 01-19-2015, 02:17 AM   #8
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Default Re: 71 Duster has been given a gift ? why
Originally Posted by Paul Precht View Post
Hi Bob, If Jerry ran in E and added the Alum head, the car would be 10 lbs heavier and the heads would remove 40 lbs off the front, not sure what you mean by 90-100 lbs. The heads may not make much ,more power than the iron heads and if the car hooks now, the weight off the front won't make any difference. It's probably not nearly as much of a gift as you think.
I have not seen Jerry run E yet . And i can't see how iron heads would only be total of 40lbs heavier than Aluminum ?
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
