Old 01-22-2015, 10:00 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
Default Re: Bulletproof TH350 ?
If you are bracket racing with the combo that you have listed in the previous posts you would be better off with a powerglide. The A-1 trans is referred to as a Protrans. These are typically light weight rotating assemblies for stock, Super stock and comp type racing. They are designed for max performance and not so much for max strength. Coan also makes a similar light weight turbo 350 its called the XLT. The cost is similar. I would talk to ATI,Coan or Rossler for a recommendation on the trans for your combo
Mike Pearson 2485 SS
