Old 01-25-2015, 09:52 AM   #13
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
Default Re: drive shaft sensor 12 bolt rear?
Originally Posted by L79racer View Post
Im using an Ultimate ll tach wih the tach facts software. Can I use an eight magnet collar or do I have to use a two magnet one. What are the benefits of the eight magnet one?
With most sensors, of this type, every time the magnet passes the sensor, the magnetic field generates a pulse.
With two magnets, it would generate two pulses per revolution.
Eight magnets would generate 8 pulses per revolution.
The sensor does not care how often a magnetic field passes it.
The problem is that the data logger, in your case the tachometer, is going to assume that two pulses are one revolution.
So, with 8 magnets, your driveshaft is going to show that it is spinning 4 times faster than it actually is.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
