Old 02-21-2015, 08:19 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Ring and pinion set up question
Dana,
What ratio are you installing?
As posted above, a pinion shim of .032 - .033 will almost always be good with a 12 bolt.
Larry Woodfin 471W
Old 02-21-2015, 08:41 PM   #2
Dana Fitzpatrick
Liked 10 Times in 6 Posts
They are 4.56's. It's a Strange housing,could that make a difference?
Looking at an old Richmond gear instruction book I have, the pattern looks like one they show as having "low tooth contact,heavy in the root of the drive gear.Move the pinion out of the gear mesh,i.e. increase the pinion cone setting.Translation, please, Lol.
My present pattern doesn't look quite as low on the toe side as their drawing,though.
Dana Fitzpatrick is offline   Reply With Quote
Old 02-21-2015, 09:05 PM   #3
pbp1
Liked 27 Times in 6 Posts
Moving the pinion in or out will not change the contact pattern from heel to toe, it will only move the pattern deeper into the root of the teeth or out toward the top edge of the tooth. Heel to toe is mostly affected by the cut of the gear and the alignment of the pinion bore machining to the carrier bearing bore. What you are looking for is the pattern to be centered between the root of the tooth and the edge of the tooth with a rounded edge on the pattern and not a pointed edge on the pattern.
pbp1 is offline   Reply With Quote
Old 02-21-2015, 09:30 PM   #4
Dana Fitzpatrick
The pattern does come to a point at the root side of the tooth. Not at all bullet shaped. I did increase the pinion shim to .022. It was .018, not .016. How do I get rid of the sharp point? Back lash is set at .008-.010. The ring gear is marked .008 from Motive.
Old 02-21-2015, 09:35 PM   #5
Dragsinger
Dana, The Strange housing could indeed require a different shim. The above posted suggestions were for a factory GM housing.
You can search the web, even Youtube, for "rear gear setup patterns" might find some help.
Also, consider talking with Strange about a suggested shim thickness.
Did the housing have a gear set? If so, the original shim would be a good starting point.
Larry Woodfin 471W
Old 02-21-2015, 11:26 PM   #6
Ed Wright
Ed Wright's Avatar
Gear sets typically come with an instruction sheet, with pictures of example patterns, and what is required to correct them. I would never do one without my old Zoom "gear setter", for measuring pinion depth. Puts them dead nuts. Good investment imho.
Ed Wright 4156 SS/JA
Old 02-21-2015, 11:47 PM   #7
Dana Fitzpatrick
Looking at the Richmond instructions, it looks as though I have low tooth contact.According to the instructions, this is solved by increasing the pinion cone setting. Does this sound like I need to decrease the pinion shim thickness?
