Old 03-01-2015, 11:51 AM   #1
rod
Liked 20 Times in 15 Posts
Default rod weight ?
I was checking my rods and I find one which is 4 grams lighter than the other 7. it is all at the big end. so how important is this?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 03-01-2015, 01:06 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: rod weight ?
Depends on who you talk to, myself I balance everything I do+/-1/2 gram, a lot will tell you this is getting carried away, my theory is closer you get rods,pistons,pins, the better your balance will be on your crank.
Mike Taylor 3601
Old 03-01-2015, 03:39 PM   #3
Roberte
Liked 14 Times in 8 Posts
I think that if you've paid for them to be balanced ,they'd have to
be going back. bob
Roberte is offline   Reply With Quote
Old 03-01-2015, 09:33 PM   #4
BillK
Liked 30 Times in 17 Posts
Rod,
I typically try to make all of them the same. Most manufacturers of aftermarket rods and pistons say that if they are all within 2 grams they are ok, but it really only takes a few seconds more to make them the same so why not do it 100%
The only exception I make is with aftermarket "H" beam rods. I do not like grinding off any of the ribbing on the bottom of those rods. Sometimes you can take some weight off the sides but sometimes it is impossible to make them exactly the same.
That being said, are you having the crankshaft balanced ? All of the pistons and rods can be within a thousandth of a gram but that does not make a bit of difference if the crankshaft is not balanced to those weights.
Bill Koustenis
BillK is offline   Reply With Quote
Old 03-01-2015, 10:29 PM   #5
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The motor will never notice it, if it bothers you though just have it corrected. Back in the early 70s when money was scarce for me I ran my BB Chryslers with unballanced parts and always turned them 7K in the lights, the motors ran as smooth as the ballanced ones.When I started working in a machine shop in the mid/late 70s I couldn't believe how out of ballance the stock BB Chyslers were. 4 grams is nothing to worry about IMO.
Paul Precht is online now   Reply With Quote
Old 03-02-2015, 03:18 AM   #6
GTX JOHN
I agree with Paul.
John Irving
741 Stock
741 Super Stock
Old 03-02-2015, 11:12 PM   #7
carl hinkson
Liked 18 Times in 10 Posts
thanks Rod in AZ
4 grams is alot for a set of rods, What rods are they ??
I seen alot of prebalanced assemblies where the pistons are still sealed in the box and the rods are still sealed in the plastic packages and guys run them all the time.
I see a lot of the GM circle track crate engines and those rods are all over the place and they run just fine lap after lap.
4 grams should not cause a problem.
carl hinkson is offline   Reply With Quote
Old 03-04-2015, 08:30 PM   #8
rod
thanks for all the replies.
if 4 grams is OK, then I am in good shape. still it ticks me off.
Rod in AZ
