Liked 759 Times in 379 Posts
clean the wheel's and tire's bead with acetone then mount them DRY, no nothing and they won't move! Been running radial slicks for 15 years, 30/10.5 and 32/13.5. sixty footing as quick as 1.17 in the Firebird to the left without issue.
#2 | |
Liked 226 Times in 115 Posts
We just switched to Hoosier 30x9 radials. Cleaned wheel/tire bead with acetone & mounted dry. Tires are moving too much for my comfort. They are now cleaned with the same method & glued. Next races Mar. 15 & 16. See how they work this time. |
Liked 11 Times in 8 Posts
I have seen the Mickey 275 tires mounted with the spray contact adheasive,but I have not seen when they were dismounted. My Hoosier radial drag slicks are mounted to Weld Wheels and screwed, with no problems,
I run mine tubeless, no screws, no glue. Either mounted dry, or just wipe the wheel with a wet rag. I have marked them, and had them slip maybe a couple of inches first pass or two, then never move after that. My 60's are nornally 1.26 to 1.30, I often have to run them as low as 13 psi to get a green light.
Ed Wright 4156 SS/JA |
Liked 224 Times in 87 Posts
Bobby , I have run radials with screws no problems .
