Old 03-16-2015, 11:43 AM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Default SBC oil pump recommedation
I had the oil pump break off at the base in my SBC 350 Super stock engine at the Gators last week during a run. scored up the crank and some bearings. didn't actually spin the bearings luckily. I had a Melling oil pump in the engine. What are some of you using for oil pumps. I am thinking about some sort of billet pump to replace the cast iron one that failed. Thanks,
Mike Pearson 2485 SS
Old 03-16-2015, 12:20 PM   #2
SSDiv6
Liked 1,590 Times in 583 Posts
Default Re: SBC oil pump recommedation
Go with a Schumman's Low Drag oil pump.
http://www.schumannsdynamicperforman...drag-pump.html
http://classracer.com/classforum/sho...t=39983&page=2
Old 03-16-2015, 12:51 PM   #3
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
There was quite a story about this a few years ago. There is actually a "better/heavier" casting Melling pump than the old # we all used to use. Can't recall the new # off hand I think it is 10552. The old standby M55 is now made with a thinner casting. If you google it you can find pages of complaints/problems etc ...
Old 03-16-2015, 05:20 PM   #4
REGGIE WINKLES
Liked 39 Times in 9 Posts
Stewart oil pump, no worries, less H.P. to operate.
Reggie Winkles 2650/Stock
REGGIE WINKLES is online now   Reply With Quote
Old 03-16-2015, 06:10 PM   #5
Liked 1,856 Times in 420 Posts
Schumann makes a nice pump. The next step up, what I'm switching to, is a Clay Valley Racing pump. They have a cover that has the pick up built in, just measure your pan. Their pump also has a wear plate between the gears and the cover, so if it gets scored, you can replace it, and not the whole pump.
Old 03-16-2015, 07:50 PM   #6
Ed Wright
Ed Wright's Avatar
^^^^^ There Ya go!!
Ed Wright 4156 SS/JA
Old 03-17-2015, 12:28 PM   #7
Mike Pearson
^^^^^ There Ya go!!
Ed, I talked to Larry this morning about his pump. He said he uses a Melling unit that he modifies. Do you know what base pump model number that he used. I am assuming you have one of his pumps. I am a bit leery of the melling pump as that is what broke in my engine. Supposedly Melling makes a higher quality line for performance engine service with a heavier casting. I will probably go with one of Larry's pumps in the end. Thanks,
Old 03-17-2015, 12:51 PM   #8
Ed Wright
Ed Wright's Avatar
Mike, I'm sorry, but I don't know which casting Larry uses. Mine is in the engine, in the car, so I can't check. Larry would tell you. He is a good guy.
Old 03-17-2015, 02:01 PM   #9
Mike Pearson
Thanks for the input Ed. I will give Larry a call. Good luck racing this year. We just finished up 5 races in 6 weeks here in Div 2. Now a couple of IHRA nitro jams next month. This is the busy time for us here in Fla.
Old 03-18-2015, 08:32 AM   #10
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
melling M-55A is heavier casting, m55 and m55hv have lighter castings,some things that will break pump are cavitation most of time pickup too close or far away from pan,or oil getting away from pickup or lack of oil, out of balance or vibration from driveline, oil pump shaft rubbing block some blocks need hole opened up or shaft that is undercut, some dart blocks need drilling for clearance around oil pump shaft.
Mike Taylor 3601
