Old 04-03-2015, 08:13 PM   #7
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: ladder bars
set your ladder bars up with 2 degree down angle with respect to the bottom of the rocker panel on the car. put a protractor or smart level on the rocker panel see what degree that is and make the bottom bar on the ladder bar 2 degrees more down angle. put 2 degrees down angle on the pinion. My car weighs 3165 and I have the same type shocks as you. I run 110 lb springs. I run my shocks 2 clicks from loose
What if the car likes a little pre-load on the right bar? Is that the 2* down bar?
Ron Gusack is offline   Reply With Quote
