Old 04-03-2015, 11:25 PM   #1
Jeff Blanchard
Default Difference in scales at tracks in Div 3
How much difference is there in the scales at the different tracks in Division 3?
Jeff Blanchard
353C / Stock
Jeff Blanchard is offline   Reply With Quote
Old 04-04-2015, 08:53 AM   #2
james schaechter
Liked 1,443 Times in 302 Posts
Default Re: Difference in scales at tracks in Div 3
Most tracks with Divisionals do a pretty good job with this. It is true scales can vary a bit here and there and occassionally there can be one so far off, they have to bring a service in to correct it. There is no real way to hang a number on the differences in advance if that is what you are looking for. Make sure you have some legal ballast to adjust up or down a bit and you will be fine. Everyone works off of the same scales so if they are light or heavy a wee bit, racers just tend to adjust. The biggest swings I have seen the last few years have been at some tracks on windy days. Even with that, the tech guys get creative and block the wind with a sheet of plywood or sometimes have you weight the car facing a different direction to get a better reading.
James Schaechter 3163 STK
Old 04-04-2015, 11:01 AM   #3
MR DERBY CITY
Liked 8,221 Times in 1,538 Posts
The worst scales in div 3 were at Stanton, Michigan , almost 40 lbs light.They no longer host a points meet. Between Indy, BG and Columbus there might be a 10 lb. difference. M.J.
Old 04-04-2015, 11:09 AM   #4
Liked 11,002 Times in 2,263 Posts
To be safe be ready to adjust up or down 40 lb. Remember you can be to heavy for a class or to light. Its always best to weigh and adjust before the first run.
Old 04-06-2015, 09:12 AM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
most time if I go get on scales very first thing in the morning,I have been way light come back later and weigh right?
Mike Taylor 3601
Mike Taylor 3601 is online now   Reply With Quote
