Then it's just ET brackets. That ain't racing.
Ed Wright 4156 SS/JA |
Liked 154 Times in 37 Posts
66W30POST |
Stock Class engine rules will remain and first qualifier will get bye run with impair field. What are benefits with heads up?
Liked 10,830 Times in 2,251 Posts
The smile on your face after the run!
Liked 13 Times in 9 Posts
Part of the "platform" issue is that some combinations receive horsepower while the same engine in a different body does not. The HP factor is an expression of an engine potential. An engine either has a certain power potential or it does not. The idea that an engine can receive HP hits in one body and it somehow makes sense that you can move that drivetrain to another body to start over with a clean slate on HP factoring is nonsensical.
While you can obviously argue that one 'platform' *utilizes* that HP more efficiently than another, it is logical that if a HP factor is raised on an engine in one platform, it should be raised on all platforms: perhaps just by a different amount. The proper way to do it would be to have the same HP across the board for a given engine combination, adjusted by a 'platform factor'. Unfortunately, this is little more than an academic discussion, despite it not really being much more complicated than they've already made it. 'Course you also have several classes in which sticks and automatics are run combined, where the automatics get a weight break in some classes, but not in others. Figure that out.
Liked 2,355 Times in 554 Posts
Stock is a performance based class. Heads-up runs are the best part. Take them away and we might as well just run the local bracket race.
Liked 325 Times in 50 Posts
What he said X 2. Is that correct. Actually I like no platform, motor only. What has evolved is since platforms were made part of the program, like the LS1 in the Vette is 35 or so less than the Camaro. It's called "Pick & Choose Platforms" so now you can pick your friends, your nose, and your platform. Maybe not in that order.
Jeff Teuton 4022 STK |
