Old 04-12-2015, 04:28 PM   #1
Liked 1,833 Times in 416 Posts
Default Re: LT-1 issue
John,
Right now, what is important is the voltage on the battery supply terminal at the ECU? Especially with the engine started and running.
There could be any number of problems caused by binding, flying debris, etc, inside your distributor.
Old 04-12-2015, 04:53 PM   #2
Lee Valentine
Liked 319 Times in 68 Posts
If you never welded the shaft in the opti spark it may have moved making the phasing wrong for the crank trigger,try another distributor
Lee Valentine 1661 STK
Old 04-12-2015, 05:46 PM   #3
John Nechiporchik
Liked 13 Times in 7 Posts
Thanks for all the info. Will continue the investigation tomorrow.
John Nechiporchik is offline   Reply With Quote
Old 04-12-2015, 08:34 PM   #4
Dave Edwards
Liked 13 Times in 4 Posts
low voltage
Dave Edwards 3852 STK
Dave Edwards is offline   Reply With Quote
Old 04-12-2015, 09:47 PM   #5
Ed Wright
Ed Wright's Avatar
You would be extremely lucky to find a dead spot on the TPS wiper with a volt/ohm meter. They are too slow. What you see on a digital meter is not real time. It is data frames, like frames on a movie film. The update rate with a meter is so slow, sweeping the TPS usually falls between data frames. You would have to move the throttle lever VERY slow to catch it with a meter. Thing to use is a fast digital lab 'scope. I always used a Fluke 98A. Very fast. Still need to sweep the TPS 15 or 20 times to be sure there is no issue there.
Stock fuel systems will hold fuel pressure a long time after the key is shut off. Factory fuel pumps have check valves. Not so aftermarket race pumps. My Aeromotive system drops pressure quickly. I wait a couple seconds after turning it on to crank the starter. Much shorter crank times if I wait for fuel pump to get the pressure up.
Problem is likely TPS, MAP related, or a tuning issue.
Ed Wright 4156 SS/JA
Old 04-13-2015, 07:38 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Once a LT-1 I had built was acting weird backfire some would'nt idle, long story short,
found rotor out of phase was almost half way between cylinders and optical sensor showed out of range,probably had slipped on shaft,I slotted the wheel and got the opti sensor in range and slotted rotor and phased it ran good then.
When rotor etc exploded could have knocked out of phase,I used a small degree wheel to turn engine to where ignition timing was so I could check phasing of rotor
Mike Taylor 3601
Old 04-13-2015, 10:16 AM   #7
Ed Wright
Ed Wright's Avatar
Sheep Boy can't post here, but thinks you may have a rubber fuel line deteriorating inside, putting crap in your injectors. If you have old stuff on your car, it sure would be worth checking.
