Sheep Boy can't post here, but thinks you may have a rubber fuel line deteriorating inside, putting crap in your injectors. If you have old stuff on your car, it sure would be worth checking.
Ed Wright 4156 SS/JA |
Liked 13 Times in 7 Posts
Will do. Flushed fuel system prior to start-up.
May be good idea to do it again and check volume after the regulator. What is the process to inspect individual injectors once removed from fuel rail? Thanks, John |
Look for debris in the screen in the top of the injectors.
Liked 11 Times in 8 Posts
John, not sure on your system but most I've seen have 5 volt reference to TPS as someone stated earlier not having the 5v volts would be a problem. Can you not view live data with a laptop on your system? If so use that to look at what the ECU is seeing in relationship to any and all sensors. I had this very thing on my set up a few years ago and it was a loose terminal in my TPS plug, it would read at times then drop out and the engine would hardly move the car. Also not sure but some systems you can calibrate most of the sensors including the TPS. Since the main inputs used for timing and fuel are the MAP and TPS, (there are others but less important as to throttle responce) I'd look closely at both those. BTW engine off does the MAP and BARO sensors read the same, and what is MAP reading with engine running?
Joe Buchanan SS/BX 3117 Last edited by buzzinhalfdozen; 04-13-2015 at 02:16 PM. |
After thrashing on this beast all day, checking all the items that were suggested, it appears that going thru the valve train and re-lashing the valves was the primary contributor.
I installed a new cam this winter with the "shimmed" lifters and appears I adjusted them too snug...and 4 valves (2 Ex and 2 In) were extremely over adjusted. So I went thru the system and re- set them all until "0" lash. Fired it up and idled like a dream....revved it up slowly and with the exception of a slight flat spot around 3000RPM, it revved right up to 7000. I'm thinking (Ed, the tune up)needs to be tweeked for the new components. Tomorrow we'll hook the lap top up and see if we can work on the flat spot. I'm thinking it's time to make an appointment with the chassis dyno guy to see if we can fine tune this thing. I hope I'm done on this issue. Thanks to all of you for your ideas and support. Special thanks to Russ Abrams for the all day text message and phone call support. John |
Liked 216 Times in 77 Posts
mind if I ask what brand lifter you used?
Thanks |
Stock GM lifters modified by Tom Russell.
