Old 04-26-2015, 06:57 PM   #1
Terry Waldron
Default 283 stocker timing problems
will not start unless i set timing at 28- 30 degrees, i usually have timing set at 38-40, is my dist. off a little ?
Terry Waldron 5619 K/S
Terry Waldron is offline   Reply With Quote
Old 04-27-2015, 09:33 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Default Re: 283 stocker timing problems
When you say won't start what do you mean exactly,it hits but won't start like timing is retarded,or just cranks without hitting at all?
Mike Taylor 3601
Old 04-27-2015, 10:19 AM   #3
Terry Waldron
starts up fine at 28-30 if i set the timing up to 38- 40 where i want it it turns over real hard, wont start at 38.
Old 04-27-2015, 12:18 PM   #4
Liked 5,125 Times in 1,953 Posts
It seems to me that if you want to start it with that much fixed timing, you would want crank the motor with a button, then flip the ignition on.
Then again , maybe I'm behind the times and you just need a bigger, more expensive battery.
Old 04-27-2015, 12:41 PM   #5
FED 387
Liked 333 Times in 180 Posts
First double check the timing then start looking at bigger battery more /powerful starter--- wiring to/from both--- we routinely run 36-38* timing in a comp car with a standard mini starter and a small 12V battery no problems--- turns right over --- ya might try Mark's suggestion crank it over then turn ignition on see if that helps--FED 387
Old 04-27-2015, 12:41 PM   #6
Everett Hill
Liked 4 Times in 3 Posts
what has changed new motor, new cam, removed dist. ,or just checking timing
Everett Hill 2134 STK, SS
Everett Hill is offline   Reply With Quote
Old 04-27-2015, 12:48 PM   #7
FED 387
how do you set your timing??? @ what rpm??
Old 04-27-2015, 01:19 PM   #8
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
What tooth flexplate?
Is your starter just a mini starter, or is it a gear reduction?
1 battery or 2?
12v or 16v?
Wade O
Old 04-27-2015, 01:35 PM   #9
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Was the motor originally a crank hub and changed to damper? If so make sure you have the right one because there are different marks on the balancer. Had a similar problem on a street motor and used a timing tape to correct the errant marks after figured it out
Old 04-27-2015, 02:15 PM   #10
John Kissel
Liked 230 Times in 94 Posts
Terry, You might could try this device MSD has called a "Starter Saver". It electronically takes out either 10 or 20 crank degrees when cranking depending on if you cut a certain wire or not. It can make an engine spin over like nothin'. Go read about it on their web site, John Kissel
John Kissel is offline   Reply With Quote
