Old 05-06-2015, 12:07 AM   #1
2021STK
Liked 17 Times in 14 Posts
Default Battery charger brand?
Looking for a good dependable 12V battery charger. Had enough of the S brand (run away voltage, boiling fluid, won't float,....) At the last Div-1 meet I saw every brand I'd heard of in use but not a consensus on the brand. Moroso was the high end for me all the way to discount store, just looking to recharge, maintain between rounds and overnight trickle.
Using two Optimas in car,
Thanks in advance
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 05-06-2015, 05:59 AM   #2
SGSST109E
Liked 126 Times in 61 Posts
Default Re: Battery charger brand?
Optima batteries must not be subjected to a charge voltage greater then 14.5 volts. I have always used a Battery tender 5 amp charger. Optima now makes there own battery charger.
SGSST109E is offline   Reply With Quote
Old 05-06-2015, 08:14 AM   #3
cad
cad's Avatar
Liked 93 Times in 52 Posts
I believe I found this link on classracer a while back:
http://www.usabatterychargers.com/
cad is online now   Reply With Quote
Old 05-06-2015, 11:25 AM   #4
John Kissel
Liked 230 Times in 94 Posts
I have a Sears model 608.718331, 12 volt, 10amp that I bought in July 1981, and except for painting the case and making a new carry strap it does great. When my "yellow top" that is 5+ years old is in our racecar it keeps it happy. Hope this helps, John Kissel
John Kissel is offline   Reply With Quote
Old 05-06-2015, 11:44 AM   #5
SC321X
Smile Re: Battery charger brand?
I have 2 red top Optima batteries in my dragster. I use a black and decker charger that will run 40 amps continuous and will keep up with the fan and water pump between rounds. It will gradually go down to 0 charge when fully charged. my dragster is an 2008 and I changed out my old optimas last year just because I figured it was time, but they were still working great. I hope this helps. I tried the S brand and they didn't keep up.
Dave D. SC 321X
SC321X is offline   Reply With Quote
Old 05-07-2015, 12:12 PM   #6
Bobby Fazio
Bobby Fazio's Avatar
I purchased the expensive Optima charger because they were paying contingency. They stopped paying contingency and the display on my charger stopped working after two weeks.
'65 Mustang SS/L & L/SA
Old 05-07-2015, 12:41 PM   #7
63corvette
Liked 359 Times in 103 Posts
I have a Davis roadster which uses a Guest Marine on board charger.
I also use 2 Optima red tops. They last 5 plus years for me in the race car and I just change them and move them to the pickup or my big mower for the last few years of their life. The one in the pickup lasted for almost 11 years before needing replacement.
I keep the race car plugged in full time at home and it works as a maintainer.
My Guest has 2 lugs that charge 5 amps each. I have the lugs tied together like the batteries. It is an on board small charger which makes it easy to just take a extension cord and plug it into a bulk head receiver on the car. Clean and simple without dragging around a charger. I have had this system since 2007 and it has worked well for me.
Guest model 2610A hard wire model
Guest model 2611A wire lead model
My 2 Cents
Rick Cates
63corvette is offline   Reply With Quote
Old 05-07-2015, 01:40 PM   #8
NHRA 303
NHRA 303's Avatar
Made here in the U.S.
http://usabatterychargers.com/Portable_Chargers.htm
Steve Tucholsky
NHRA 303 is offline   Reply With Quote
Old 05-07-2015, 10:08 PM   #9
2021STK
Originally Posted by NHRA 303 View Post
Thanks for this reference.
I really like the "Made In USA" and the tech write up, do you have one of these? Anybody with experience owning one of their products?
Dave Outten
2222 S/SS/SST/SG/HR
Old 05-07-2015, 11:54 PM   #10
2021STK
Looking for the best between rounds charger until we get a Hi-Amp alternator on the car.
Dave Outten
2222 S/SS/SST/SG/HR
