Old 05-18-2015, 03:46 PM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Default Re: Rear Gear Lube - Synthetic Or Conventional?
Originally Posted by 69camz28 View Post
I have a Strange S60 (Dana 60) in a 69 Camaro. I had it re-geared recently to a 4.30 gear and it has a Tru-Trac carrier. I was told that the gear company (Motive) recommends conventional gear oil - 75/140, and not to use synthetic gear oil. Thoughts on this?
Is the tru track a posi unit? if so use what Strange tells you to use. if it has a spool and is race only the synthetic works fine. I use it in my Dana race only with spool.
Mike Pearson 2485 SS
Old 05-18-2015, 04:31 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
just in the last season or two I have been pushed with some resistance to trying synthetic oils. I am pleased with the results to the extent that I bought into an Amsoil racers program.
Amsoil was in the very pioneering phase of synthetic engineering. They have good proven products and support a wide range of sportsman racing.
I think Amsoil products are a good choice and will be running them in the Super 10.
Larry Woodfin 471W
Old 05-18-2015, 05:06 PM   #3
69camz28
A True Trac is: The Detroit Truetrac is a helical-gear style performance differential that maximizes wheel traction and enhances driving and handling characteristics.Operation The Truetrac operates as a standard or open differential under normal driving conditions, allowing one wheel to spin faster or slower as necessary. When a wheel encounters a loss of traction or the terrain changes, the gear separation forces take effect and transfer torque to the high-traction wheel. The helical-shaped gears mesh with increasing force until wheel spin is slowed or completely stopped. When the vehicle exits the low traction situation, the differential resumes normal operation.
Performance Operation of the Truetrac is smooth, quiet and automatic. The unit will engage without any driver knowledge or action required. It also has no wearable parts and requires no maintenance, meaning less time in the garage and more on the road.
69camz28 is offline   Reply With Quote
Old 05-18-2015, 08:05 PM   #4
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Rear Gear Lube - Synthetic Or Conventional?
I'm using synthetic lube in my 4:30 geared Dana 60 as well,, it has a spool.
Danny Durham
Old 05-19-2015, 07:40 AM   #5
Lou Jeffery
Whenever the subject is Synthetic or Conventional the responses always say "We run it and have no problems". So we understand that there are no negative effects but what are positives? ET, durability, consistency?
Lou Jeffery is offline   Reply With Quote
Old 05-19-2015, 10:35 AM   #6
Dragsinger
Lou, good question. I have some feedback and will work it up and post later.
Larry Woodfin 471W
Old 05-19-2015, 10:57 AM   #7
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
I think this is one of those ask 10 people and get 10 different answers kind of thing. I run Royal Purple synthetic in my Plymouth but run what Strange recommended (and sent) in my Camaro. The brand name escapes me but it was a non synthetic oil.
Jon Sarrett is offline   Reply With Quote
