Liked 6 Times in 6 Posts
Jegs has the 12v 6.9lb Braille battery for $150 and I was wondering if its legal to have in the battery tray in the engine compartment in Stock. Does it have to start the car? What if I have a 16v battery in the trunk that starts the car? Is the small size an issue?
thank you |
Liked 15 Times in 7 Posts
Michael I have used the 17 pound braille for the last 2 years in the front location, but i only have one battery and has worked great,buttt,,,,in the rule book it says two batterys if used must be same size and weight ...Just depends on what your nhra official says....Bryan D stk511
Liked 535 Times in 110 Posts
I know if a second battery is used (in the trunk), it must be the same type and group.
Jim Kaekel 3836 STK |
Liked 4 Times in 3 Posts
Yes sir we have been successfully using and selling them for over 5 years best batteries we've had since my old Motorcraft group 31s 1000 CCA 70lb bricks
2 in my 65 Mustang SS car 1 in each of our EFI stockers which both have power windows and locks too
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net Last edited by Alex Denysenko; 05-13-2015 at 08:46 PM. |
Liked 77 Times in 15 Posts
Michael,
You can't go wrong with a Braille battery (unless it isn't correct for the application), and they support not only drag racing in general, they specifically support S/SS racing. All three of our cars will be running Braille Batteries. You'll see the signage and product on our cars and commercial transporter next week at Maple Grove. Great company and people. Stop by and check out the battery we are running in our stocker, lightweight and no need for two. -Matt |
#6 | |
Liked 52 Times in 9 Posts
Jim Morgan 1916 , 9916 STK |
Liked 33 Times in 16 Posts
Using the B3121 in the Camaro and the B2317 in the Mustang. Great batteries, but I can not recommend their charger (12310) . https://www.braillebattery.com/index...argers/b123101
The charger is great for home/shop use with standard 120v service, but it will not excite/operate on any generator I have tried at the track. ![]() ![]() ![]()
Rich Taylor I/SA - 321 |
Liked 61 Times in 12 Posts
Michael, I have the 21 lb Braille battery in my car this year and have had no problems with it. The rule book does say if you are running two batteries, they must both be the same size and the front battery must start the car. I just have the one in front.
John Bender E/SA 1967 GTXw
John Bender 1969 STK |
Liked 4,382 Times in 503 Posts
Alex what Braille battery would you recommend for the EFI stocker? Is 475 cranking amp enough? I'm using a 6 year old optima red top that weighs about 35 lbs and would like to take some weight off that front end.
#10 | |
