Old 05-25-2015, 12:50 PM   #1
HIGHOCTAIN2000
Default Piston to valve
What is the minnium piston to valve clerance you have run, aplication is stocker with auto trans and solid lifter.
HIGHOCTAIN2000 is offline   Reply With Quote
Old 05-25-2015, 01:03 PM   #2
Liked 1,880 Times in 422 Posts
Default Re: Piston to valve
On the intake, I run as little as the piston to head clearance plus 0.010", on the exhaust, I like to see 0.070".
Old 05-25-2015, 05:16 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
You are my hero Alan ! ...I thought I was brave at .025 !
I do go closer @ .060 on the exhaust though.
Old 05-25-2015, 05:25 PM   #4
Tom, I've run 0.050" total on a big block intake, at 0.00" deck with a 0.042" Cometic head gasket. I've run tighter than 0.070" on the exhaust, but I know that I have kissed the piston with a valve or two when the exhaust valve bounced on the seat. I know valve bounce can happen, so I won't tell anyone to run tighter than 0.070" on the exhaust. Valve bounce on the intake will not cause a clearance problem, just beats on the valve job and makes Jimmy Bridges chew me out.
Old 05-26-2015, 08:07 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
The driver is also a big factor in how close you can get by with.
