Old 11-12-2007, 03:57 PM   #1
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Question I just read a rumour about diapers...
and allegedly, the requirement for cars running 7.50 - 9.99 to have one has been dropped. Anyone else heard, or know if this if factual ??
Dinsdale is offline   Reply With Quote
Old 11-12-2007, 04:17 PM   #2
Sean Ward
Sean Ward's Avatar
Send a message via AIM to Sean Ward
Default Re: I just read a rumour about diapers...
you better get one you do have to have one
Sean Ward NHRA s/ss/comp#2882
SW4 MOTORSPORTS
Sean Ward is offline   Reply With Quote
Old 11-12-2007, 04:20 PM   #3
7820
7820's Avatar
I sure hope so. I would think it will cause excessive engine heat and build heat very quickly. Not good in the Southwest.
Where did you read this?
7820 is offline   Reply With Quote
Old 11-12-2007, 07:03 PM   #4
Wayne Taylor
Liked 8 Times in 1 Post
we (Super Stock) have another year until we have to have them. I will wait to the very last minute until I get one. I learned my lesson with the muffler farce. BTW would anyone be interested in a high quality pair of mufflers from Dawson. Never been used.
Wayne Taylor is offline   Reply With Quote
Old 11-13-2007, 10:07 AM   #5
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: I just read a rumour about diapers...
Hi this Dennis Ridgeway from DRE Engine Diapers the last I have heard is super cat. this year then S/S next .There is some confusion on spec you will only need a NHRA accepted diaper not a SFI 7.2 if you have ? call or post ? this is not a ad it is information
DIAPERMAN is offline   Reply With Quote
Old 11-13-2007, 10:47 AM   #6
Patrick Kelliher
Angry Re: I just read a rumour about diapers...
If they do mandate diapers in the Stock/SS classes it is just another example how NHRA is displaying their lack of knowlege when it comes to our classes. How would we be able to adjust oil levels during a weekend. Testing would be an absolute nightmare. I know DRE is a sponsor of this site but I am tired of hearing them push for something that would be so bad for out classes.
Patrick Kelliher is online now   Reply With Quote
Old 11-13-2007, 10:47 AM   #7
7820
7820's Avatar
I'm sure it can be done...and I'm also sure that there are more complicatied applications of a diaper than mine....but it will be exciting to see a diaper on a stock front end of a Pontiac Firebird like my '72.
I have a concern for myself and the person in the lane next to me should a problem should come up but I also have a concern that the diaper will retain heat and cause premature failures and even a fire should the engine let go. Recing in the Southwest in the summer can be cruel to everyone and everything.
Old 11-13-2007, 11:58 PM   #8
JEFF ESSMANN
Thumbs down Re: I just read a rumour about diapers...
between my header and oil filter 1/2 inch of clearence, on the front of motor 1/4 inch between the crossmember and oil pan the drag link runs right underneath the front of the pan and is so tight if i put a grease zerk in the tie rod end it hits the pan. now how in the H----- am i supposed to put a diaper on that
and by the way its a 72 gto with 20k original miles cutting the crossmember is out of the question
Jeff Essmann 5780 ss/ja
WEB SITE WITH MY RACECAR
JEFF ESSMANN is offline   Reply With Quote
Old 11-14-2007, 08:20 AM   #9
DIAPERMAN
Patric just for the record we have never pushed diapers to NHRA and also we are sportsman racers.We are the ones that pushed to get the SFI 7.2 rules wipped out.We are trying to help guys with questions and we are one of the only companies doing custom sportsman diapers. Jeff we just built a diaper for a similar application.I have told guys before I am here to help with this rule problem Patric if you would give me a call I would like to talk to you thanks 217-454-5289
