Old 06-01-2015, 11:41 AM   #11
HawkBrosMav
Liked 302 Times in 73 Posts
Default Re: Rockers for stock Eliminator 5.0 SBF
Originally Posted by Chris1529 View Post
Don't the Ford Racing rockers the OP was looking for have to be shimmed as well?
Yes and no.. You only have to shim them to get the rocker to sit on the top of the valve correctly.. The cup where the push rod rides is adjustable so if your valve is the correct length you should not need shims at all
