Liked 99 Times in 21 Posts
Rick, I played with a 75 skyhawk 231 Pure stocker a decade and a half ago, and tried some 4 banger springs in it. The car sat so low it looked like it had no springs in it. With out removing the jack from under the car I reversed the process and put the stock springs back in. My car would not spin in a carwash so weight transfer was not an issue for me, mine may have ran faster if I had welded the upper a frame bushings to prevent needed movement LOL Hope this helps. Don Jackson
So Don, maybe just stick with the V-8 springs to start with? Maybe I should just take out the V-6 springs from my donor, that way if I want to try them, I already have them,
I would get the V6 springs for sure in case you need them. The ride height may be too high with the V8 springs and the V6 engine. According to the NHRA Class guide there is approx. 190lb. difference in the 77 starfire with the 6 and 8cyl engine. I can't think of any difference in the car except for the weight of the engine and maybe a little larger radiator. The 4 banger springs I tried came from a Vega (If my weak memory serves correct). I think the vega 4 is mostly aluminum, maybe even the block too. 4cly. springs from a H body with a pontiac 4 may be stronger than the vega springs. hope this helps. Don Jackson
All info is helpful,Don. Thanks to everyone who has replied so far,
![]() Rick |
I had a street strip v 8 monza for years. It was a fun car and went low 12's. One thing about the Monzas that you should keep an eye on are the tie rod ends and ball joints. They aren't real sturdy and actually will fail. Just check them real good. I have heard that some Superstock cars of that type used some S-10 front end components, but I am not sure how they did that. It might be something to look into.
James Schaechter 3163 STK |
