Old 06-16-2015, 11:23 AM   #41
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: Fake battery, dq or not
PER NHRA BOTH BATTERIES MUST BE THE SAME!!!!!!!!!!!!!!!! --- that means the same dimensions and weight---if you run a battery in the front that is either larger/heavier than the battery in the rear OR to put it another way the battery in the rear is larger/heavier than the battery in the front -- THEY ARE NOT THE SAME--- YOU ARE ILLEGAL--YOU ARE CHEATING----- now NHRA has come out and said that if you do this ( run 2 different sized batteries)/you will be asked to leave you are thrown out /disqualified/get no points/race counts toward your total ETC. ETC. and a lot of other things---- what don't you people understand??? Its not open for discussion--- so go out in the garage and look at both batteries if you run 2 and decide for yourself if the battery in the front matches up to the battery in the rear--- if it does go back to bed--- if it does not you have 2 choices --- either get 2 batteries that are the same so you WILL BE LEGAL or keep using your current battery set up andcontinue to be ILLEGAL
Old 06-16-2015, 12:28 PM   #42
Mickey Whaley
Lightbulb Re: Fake battery, dq or not
Anybody remember the gong show?
Mickey Whaley is offline   Reply With Quote
Old 06-16-2015, 03:41 PM   #43
jimmyparker
Liked 309 Times in 88 Posts
Default Re: Fake battery, dq or not
Are we saying two fake batteries would be legal?
jimmyparker is offline   Reply With Quote
Old 06-16-2015, 04:09 PM   #44
FED 387
YES per current NHRA guidelines however they must start the car!!!
Old 06-16-2015, 11:09 PM   #45
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
You mean Gene Gene the dancing machine?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 06-17-2015, 07:36 AM   #46
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Or The Unknown Comic?
Lane Weber
Old 06-17-2015, 10:27 AM   #47
Chris Barnes
If you have an engine in the trunk, does it have to be the same as the engine under the hood?
Chris Barnes is offline   Reply With Quote
Old 06-17-2015, 12:27 PM   #48
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
that's funny
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 06-23-2015, 10:50 AM   #49
Mickey Whaley
Talking Re: Fake battery, dq or not
I have 2 in the front dont know if it is possible to have to in the back
Old 06-23-2015, 11:52 AM   #50
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: Fake battery, dq or not
Now you got me wondering where a Corvair has its battery!
LOCOMOTION Racing
