Old 06-28-2015, 06:30 PM   #1
J.R. Haddad
Liked 1,470 Times in 308 Posts
Default Oil contamination!!
We were changing oil on the Race Car, and the oil (Mobil 1) had an orange colour to it. Pulled out the motor and the oil is gummy, and the pan looks likes it has primer painted on the inside. All else looks good. We tried a smaller set of headers last week, and it was very rich. We were using Renegade 12 fuel. Also, there was NO WATER in the oil. We are at a loss. Any ideas would be greatly appreciated. J.R.
J.R. Haddad is offline   Reply With Quote
Old 06-28-2015, 07:41 PM   #2
Dyno
Dyno's Avatar
Liked 692 Times in 205 Posts
Default Re: Oil contamination!!
Fuel contamination
Old 06-29-2015, 07:33 AM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
JR, did you run a break in oil or use a moly oil additive before the Mobil 1?
"That'll never work....."
Old 06-29-2015, 05:23 PM   #4
J.R. Haddad
Hey Al, how are you? Al, like yourself I bought the car already running.
Although we had it apart over the winter, we didn't make any changes to the shortblock or cam, so no, we didn't use any additives. Thanks, J.R.
Old 07-01-2015, 10:58 AM   #5
Cam
Cam's Avatar
If you can get a sample of the oil and fuel to an oil analysis lab they will be able to define any cross contamination.
Cam Chowen
6067
1994 Camaro C/S
Cam is offline   Reply With Quote
Old 07-01-2015, 12:00 PM   #6
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
If you bought it T/K maybe it is primer? Some guys will use red primer in the valley etc instead of using Glyptal. Might explain the color in the pan.
sst7250 is offline   Reply With Quote
Old 07-01-2015, 01:20 PM   #7
J.R. Haddad
It is a new pan that we just put on last month. But I like the way you think!
Thanks, J.R.
