Old 07-05-2015, 10:41 PM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Class question
Might be tough to pass that '91 off as a '85 body style for a carb.
Rich Taylor
I/SA - 321
Old 07-06-2015, 11:38 AM   #2
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Yep.
You will have to change the front nose, interior dash assy. (and door panels), the side quarter windows as well as the tail lights to make it appear as an '85.
Here are the numbers for an '85 Mustang
http://www.classracerinfo.com/CGPage...5&MAKE=Mustang
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 07-06-2015, 12:10 PM   #3
Rory McNeil
A 4 barrel carbed 85 Mustang 5.0 is a stick only combo, in addition to all the body changes to convert a 91 to a 85, the 85 engine also uses different head castings, pistons, not to mention you need to use the correct Ford E4 intake manifold and an approved carb. The easiest way for this car to run in Stock would be to put the EFI back on, and run it as a 87 thru 93 Mustang, which is legal with either a stick or automatic, plus you would not need to find,paint and install the 85 body panels and interior. You may want to give this effort some serious consideration and do some research before turning a wrench.
NHRA 6390 STK
M/S 85 Mustang
Old 07-06-2015, 04:19 PM   #4
ALMACK
ALMACK's Avatar
I totally agree with Rory ^^^
Good advice.
I/PS '95 Mustang GT
Old 07-06-2015, 04:34 PM   #5
HandOverFist
By all means, join the efi tuning ranks...it's so easy.
Rich Taylor
I/SA - 321
Old 07-06-2015, 08:15 PM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
In a nutshell, whatever year you claim the car to be. Body, interior and engine has to match as it came from the factory. The NHRA engine blueprint also lists the approved casting numbers that are mandatory to match year claimed. Camshaft cannot exceed the lift as specified in the blueprint guide. OEM EGR plate has to be in place if it was a factory piece. Lots of rules to abide by. If you want to throw go fast parts at a car then Stock is not for you. If you like a challenge at making something faster with OEM parts then jump in the water is fine! Just keep in mind making these cars competitive is not for the faint of heart or wallet! Its good to ask questions, and even better to go into this with a very well thought out plan before acquiring parts.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 07-06-2015, 08:35 PM   #7
7423
Why Rich.....................I sense a bit of sarcasm in your tone.
7423 is offline   Reply With Quote
Old 07-06-2015, 11:07 PM   #8
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
It is like teaching an old dog new tricks...
Like learning the steep daunting computer nomenclature.
Here is where you kids can help!
Actually not that hard.
Check out TunerCat which has products and SW to tune your Computer.
D
