Old 07-15-2015, 07:48 AM   #3
rod butcher
Liked 132 Times in 27 Posts
Default Re: 82-92 F body brake help
Check brake pressure front and rear. It should be above 1000 - 1200 psi. The rear brakes hold the car. We used to use extra thick shoes and uncut drums in the old days to hold it on the line. Now a dual caliper set-up in the rear is the norm. Our small block car holds at 3400 on 2 step with 4 wheel disc.
rod butcher is offline   Reply With Quote
