Old 07-20-2015, 10:13 PM   #1
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: Aftermarket Steering Column
Thanks guys. The bolts are 1/4" diameter by 1 1/2 " long not including the head.
Good idea about the set screws.
SSGT Mustang is offline   Reply With Quote
Old 07-20-2015, 11:09 PM   #2
SSDiv6
Sorry, should have been more specific.
Need the grip length; from the end of the head to where the threaded portion starts.
Old 07-21-2015, 09:33 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
I welded the joints on mine except for the connection to the steering box. The kit I used had a split collar to keep from pulling back on the column. It was a Jegs kit.
Mike Pearson 2485 SS
Old 07-21-2015, 10:13 AM   #4
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
In addition to the AN bolt, I've seen washers like this used to spread the load over a larger area and keep the tube from collapsing. It also seems to me that it would be beneficial to have a solid section of shaft where the u joint is bolted (with some sort of plug inserted into the column). Not sure if this would be overkill or not.
https://www.pegasusautoracing.com/pr...oduct=3077-003
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 07-21-2015, 12:30 PM   #5
SSGT Mustang
Thanks a bunch. That's great information.
I was actually thinking about welding in a bolt tube inside for each bolt, but forgot about that.
Thanks to each of you.
Old 07-21-2015, 02:24 PM   #6
SSDiv6
In lieu of the AN4 bolt that Pegasus recommends, use either an MS21250-04016 or NAS6204-16. They are built to the latest specification and 3 times stronger than the AN4 bolt.
The bolts shown above and in the links below, have a 1.0" grip. depending on the diameter of the joint and the spacers, the length may vary.
You can use the AN365-428A nuts at the other end.
You can also procure the fasteners from Aircraft Spruce.
http://www.ebay.com/itm/Close-Tolera...item1e9ff8217b
http://www.ebay.com/itm/1-4-MS21250-...00b5ac&vxp=mtr
Old 07-21-2015, 07:00 PM   #7
SSGT Mustang
I like the ones with the safety wire holes drilled. I'm a little hesitant about buying those off of ebay. You never know, they could be Chinese knock offs.
Do you know a vendor that comes to mind?
I really appreciate the help. This makes me a whole lot more comfortable with this deal.
