The maverick has better ETs on footbrake than transbrake even though transbrake pops a better wheelie. The ladder bars are in middle hole should they be somewhere else?
Over the years I worked in a transmission shop in Nashville, I worked mainly on racing transmissions, and in around 90% of the Super Stock cars, a foot brake transmission was always measurably quicker, consistently. We even built identical transmissions, except for the valvebody, and in nearly every case, the foot brake setup went quicker, regardless of how the chassis was adjusted, even in 4 link cars. We also tried changing rear end gears and low gears in the transmissions, as well as torque converters. In many cases, I think it may be that the engine is happier with the RPM held well below the flash speed, so that the converter flashes hard/higher and does a better job of multiplying torque. Also, a torque converter really needs to be built for the way you intend to use it, either with a transbrake, or foot braking.
I think the modified cars, and maybe some others with high RPM small displacement engines that need a very high stall speed may be quicker with a transbrake, if the car can be adjusted for it, simply due to how hard it is to make the converter work well. I know they are easier to drive well with a transbrake.
Alan Roehrich 212A G/S |
Liked 57 Times in 33 Posts
Bobby I agree with Alan. (yes I know Alan, it is hard to believe). On a side note tho, I will say that I believe you have to take every variable into consideration. Like my car with the Cleveland, it likes to leave off the two-step (haven't tried a transbrake yet).
Duane Eiskant 1354 Stock/Super Stock |
Liked 369 Times in 127 Posts
I have never drove a transbrake car, but does the t.b. preload the car's suspension like foot braking does ?
Or is the suspension relaxed while on the brake ?
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
OK.
I can see where the footbrake might be quicker (e.t. wise) than the t.b. then.
#7 | |
Liked 4 Times in 4 Posts
Alan, When you say the footbrake was quicker, do you mean footbraking while leaning on the convertor or launching from an idle? JimR
Jim Rountree |
#8 | |
It is extremely important to note that I'm talking about a very well tuned car, if you have a car you just can't get to rev up or flash quick and clean, it's not going to run well foot braking.
Don't forget the rollout difference when comparing your ET's.
If the transbrake launch is picking the fronts straight up out of the beams rather than getting the run at it rolling out, it could be a .03-.05 difference. |
Liked 11 Times in 8 Posts
The Carter carburetor in the AMX does not have enough acclerator pump shot to foot brake. That could be a problem in other applications, making the transbrake faster.
