#81 |
Stop the insanity!
#82 |
Liked 22 Times in 22 Posts
Yes, really. The breakdown on the $7,000 engine.283, .090 over, $600 honed and lifter bores bushed, high-tech dual plane, $250 dollars, port work, $100, 29 year old Pistons bought from Rick Katterjohn, and lightened by Rebco, $500, stock rods finished by Al Parker, $200, stock 283 crank, and balancing, $300, used Moroso oil pan, $100, dart 200 cc heads, angle milled, and valve job by Al Parker, $1,200, cam by Comp, $275, roller lifter by comp, $300, cloyes hex-a-just, $150, Howard rocker arms, $250, push rods, $100, used stud girdle, $100, total seal rings, $300, bearings, and gaskets, $300, super sucker spacer, $100, z28 oil pump, $25, ATI steel dampener, used, $150, used water pump, $50, used 1 and 7/8ths headers, $150, damn best 750 cfm $1,200. Misc. $300. I know because I assembled it. Don't know the breakdown of the other engine, but it was to be the hot item. And it did run.
don,t have one |
#83 |
Liked 684 Times in 289 Posts
#84 | |
Liked 574 Times in 212 Posts
Gary Hansen - SS/FA 4911, B/SA 4911 |
#85 |
Afraid Denver is not an indication on the pulse of sport as it always has low car counts. Columbus divisional 102 stockers 79 super stock.
#86 |
Thank you. It actually was a shock.
don,t have one |
#87 |
Liked 32 Times in 19 Posts
Gentlemen, I appreciate the place to discuss my view of Racing Class in Stk and SS.
There is a place for every type of racing in these eliminators. I appreciate all your input and opinions. I appreciate you listening to my thoughts. Lets end this discussion with a hand shake and a thank you at this time. Good Luck and I hope to see you all at the races.. Dick Butler |
#88 |
Liked 54 Times in 18 Posts
As far as crate engines go in stock cars if you have the money & know the right people you can buy the special head bolts & intake bolts that cant be duplicated . So why would that work in NHRA any better ? If you have claimer engines the guy with the money just keeps buying the fast guys stuff until he gets tired of building new engines.
#89 |
Liked 489 Times in 227 Posts
Who Builds a car for just for class racing and not for the bracket part of it ?
Jake Biermann |
#90 |
Liked 1,034 Times in 368 Posts
Just left the divisional at Columbus... Final was heads up in Superstock with at least 2 other heads ups in the 3rd and 4th rounds...If you built a motor for the " Bracket " part of it ....you left early .
Jeff Niceswanger 3740 SS |
