Liked 5,125 Times in 1,953 Posts
Kevin,
I've been avoiding this one, hoping someone else would handle it. You are pretty much correct in your analysis I believe. The theory behind the 7" is #1, lighter weight, which is always good, and # 2, to be able to achieve a higher stall without having to bend the pump fins into much of a negative configuration. Now, seeing the stator is actually physically smaller than the 8" Opel style unit, you are going to have a hard time getting a fabricated 7" stator to be able to multiply the same amount of torque as the 8". Remember, at the approx. 2 to 1 multiplication ratio , the more torque you start with, the more you'll have after the converter. If your car is in the middle of the pack now ( not necessarily yours personally), you can see where the problem lies. There are still plenty of top qualifying SBC cars that are still using 8" converters. If your car is not there yet, you'd be wise to spend your money elsewhere right now. The 7" converter is not going to be the magic bullet you're looking for...in my opinion.
Liked 507 Times in 116 Posts
We tried a 7 inch convertor in my wife's GT/JA 85 Cutlass 327/250 PG. Back to back with our normal 8in convertor it lost a tenth. Flashed 200 RPM more that the 8 inch. We found the convertor was falling back on the flash point when it shifted. We lost a few hundredths in 60 ft as well.
68 Chevy11 327 F/S |
Liked 99 Times in 60 Posts
Kevin,
I just when through the discovery process of 7" vs 8" with the Super 10. My final decision came after talking at length with Gary Hettler and Charlie Plott with ATI. ATI built me a high stall, mechanical diode 8" converter that is the cat's meow ![]()
Larry Woodfin 471W |
I have two friends that went to 7" converters in their SS/GT carbureted cars. Already fast, sorted out cars. Both picked up everywhere. I decided I had to have one of those!
Two 7" iterations later, my 8" ATI was still quicker and faster. Depends on the combo, like many other things. Or, I'm doing something very wrong. A strong possibility. LOL LT1 SS car, 3 speed.
Ed Wright 4156 SS/JA |
Liked 748 Times in 137 Posts
Thanks for all the replays guys. We seem to be seeing a pattern here.
Hopefully the converter supplier will work with me on exchanging it for an 8"....I would certainly hope so since he recommended the 7".... |
#6 | |
Could race weight and RPM range of the two examples be factors in the 7" converters working? Thanks |
Liked 333 Times in 180 Posts
7 inch convertor typical stall is in the 6000-9000 RPM range
8 inch convertor typical stall is in the 4000-7000 RPM range Where is your peak power? If its in the lower end of those ranges a 7 will not help you |
I'm thinking so. Both lighter cars, both with Quadrajets, both rev higher than mine.
