Old 08-03-2015, 12:59 PM   #1
pjfouts
Default Issues with my Stocker in need of a carb
I was running 45-55 under at the begining of the year then all of a sudden I lost 4 tenths. I have replaced the trans, converter, and had the engine refreshened by Jeff Taylor still have not got back my 4 tenths. I am at a loss for where it went.
I am now looking for a Quadrajet 750 CFM for my Olds 307.
Anyone have one that I could try or buy to see if thats the issue?
The car is just not pulling like it used to and we've checked multiple converters so that's not the issue. The rear end is clean nothing wrong there either. The Carb is the last place to check that I know of.
shoot me an email if you have anything that may help pjfouts@yahoo.com. I will be running st.louis divisional hopefully this weekend since I still cant qualify just slow is all.
Thanks,
PJ
pjfouts is offline   Reply With Quote
Old 08-03-2015, 01:41 PM   #2
JRyan
Liked 112 Times in 31 Posts
Default Re: Issues with my Stocker in need of a carb
PJ,
For starters, the 307 takes the larger 800 cfm carb. Next, I'd look for bad grounds.
Jerry
Old 08-03-2015, 01:52 PM   #3
Future Super Stocker
Did you check your valve lash and timing? Also make sure the distributor is locked down. I don't see the carb losing 4 tenths unless the air and fuel passages have something blocking them. Metering rod on the hanger??
Future Super Stocker is offline   Reply With Quote
Old 08-03-2015, 02:53 PM   #4
Dick Butler
Liked 32 Times in 19 Posts
Have you checked amt of fuel being pumped at the carb? Timing is possible. Check for chassis bind. Does it do burn out straight and drive straight.
Old 08-03-2015, 03:36 PM   #5
MR DERBY CITY
Liked 8,075 Times in 1,530 Posts
PJ, just a couple more items to check. How old is the battery, I've seen seasoned veterans pull the engine for a rebuild only to find out it was the battery. Do you run a MSD .? It could be giving you problems. Lastly, pull the fuel line at the carb and tell me how many seconds it takes to fill a gallon jug. For your application you should be filling the jug in under 30 seconds. Remember, it's all about the Wally !!"........M.J.
Old 08-03-2015, 03:51 PM   #6
Did it lose big time 60' , or are the numbers slow ,all the way?
What was it supposed to lose in the warmer weather?
Need more info...
Old 08-03-2015, 05:15 PM   #7
rod butcher
Liked 132 Times in 27 Posts
I would change MSD box, coil and do like MJ suggested with the fuel flow. Check to make sure brakes are free. I will be at Bowling Green pts. race if you need to try on of my spare carbs.
rod butcher is offline   Reply With Quote
Old 08-03-2015, 06:07 PM   #8
steve krumlauf
Liked 2 Times in 2 Posts
Pj check the line between the pump and the fuel cell it's the only one in the system that has vacuum on it and after some time the inside of the hose collapses and the outside look fine had this issue a few years ago and it was hurting mine 4tenths and it wasn't missing.
steve krumlauf is offline   Reply With Quote
Old 08-03-2015, 06:40 PM   #9
pjfouts
Thanks all I will check that tonight. And I believe you're right it is the 800 I was mistaken from a previous conversation.
