Old 08-10-2015, 06:42 PM   #4
Bill Edgeworth
Default Re: Mopar Mechanical Oil Pump Volumes 383 etyc
Originally Posted by John Lang View Post
Anybody have an idea of the volume's and pressure's of there various pumps for the various B, and RB wedge engines ! Or what could be the cause of too MUCH oil pressure ? This on my SS Hemi, which has a Milodon dual line oil system ! I have 85# at idle, and over 110 when you wing the gas ! ! I've changed springs etc ! I've have been told to take the Milodon pump out and replace it with a stock pump but use the Milodon cover, and filter mount, and dual pickup ! That scares me ! Anybody have any ideas, this is a Fresh Rebuild ! ...John
Years ago Alan Lee built a low deck 500 for me and I took him what I thought would be best for a 7500RPM B motor. I sent him a fancy 10qt Charlie's pan with the kick outs, the dual swinging pick up and the Milodon pump. He told me that just about all of it was not necessary and basically gave me the same advice you were given.
A coupe things he said in particular was that the big pump just eats horsepower and the pan was way overkill for that particular B engine because they have really good drain back characteristics .
As for the pressure issue it may be an issue with the bypass/pressure relief circuit flow capacity.
BTW that engine worked just fine with the Milodon pick up and stock pump.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
