Old 08-13-2015, 10:02 PM   #22
Danny Ashley
Liked 110 Times in 29 Posts
Default Re: carb air entry pan for the Super 10
Terry:
Yes it does but Holley and Quadrajets both use a 5 1/8 air cleaner. The only thing to watch when using one on a Q-Jet, sometimes it requires a slight modification because the accelerator pump lever may hit. Also when used on a Pontiac carb, a hole needs to be drilled for the front vent tube. Easy fix for both.
Danny Ashley is offline   Reply With Quote
