Old 08-14-2015, 08:15 AM   #4
Marty Hignight
Liked 23 Times in 14 Posts
Default Re: How to get brake pedal out of 89 Mustang
You do need to change the ratio with aero space master Cylinder. It is hard to get out like hand over fist said. Once it is out you drill the pedal for a new bolt that changes the ratio. I have 4 wheel disc from aero space on my 1988 and can get 1900 plus psi pressure. I did put a line lock on each front wheel. I can hold 3000 rpm pretty easily
Marty H
Marty Hignight is offline   Reply With Quote
