Old 08-14-2015, 12:01 PM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: battery mounting,kill switch Q?
Originally Posted by Dave Muller View Post
I don't think he meant it that way. I think he's asking, Does the alternator connect to the same side of the switch as the battery, or to the opposite side of the switch?
I'm thinking the same side as the battery, that way when the switch is off there's no chance that the alternator will continue to power the engine and fuel pump. But I don't know for sure, it's been a very long time since I've run a car with a trunk-mounted battery.
That would be correct. I tried connecting my alternator to both sides if the switch to solve my battery drain problem and connecting it to the car side produced run-on. I saw no difference between connecting the alternator to the battery side of the switch and the battery positive itself, so I went with the battery pole because there's more room up there and I'm not sure Tech wants anything but the battery connected to that switch.
If an alternator shuts itself off correctly, it can be connected to the battery side of the shut-off switch. Mine won't.
Dale
Dale Shearon
68 Mustang 6394
Old 08-14-2015, 07:16 PM   #2
Dave Cook
Dave Cook's Avatar
Keep it simple, safe, and NHRA legal, get a double pole disconnect.
Dave Cook is offline   Reply With Quote
